Turbo
BlacktopturboSX
Car: S13 Nissan Silvia
Hey guys,
Im planning on upgrading my turbo from stock to Gt2871R, I have all the work on the body done to handle it and I know I need higher injectors and a new MAF, but i think i read somewhere that it dosnt just bolt on......is that true? What else will I need? And what would it take to put on a GT3071R?
otterman
For the T28 other then what you mentioned, you'll need new oil lines and fittings. I'm not sure if you can use the stock manifold and o2 housing.
GT30 you'll need manifold, oil lines, o2 housing, wastegate and some fabbing done on the hotpipe if you go top mount.
