turbo
mitsi
I am going to buy a 95 nissan with 149,000 miles on the car. I want to put a turbo on the car, what will it take for a motor with that many miles on it to handle a turbo and not break.
240walker
Car: 1992 240sx hatchback
seriously...a good tuning and some luck. also depends on how the car has been driven before you got it.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Depends on if some idiot drove the car without oil in it etc... really hard to say... if possible get a compression check before you buy the car...
crzycav86
Car: 93 Nissan 240SX KAT
quit posting and start searching.
7GrandGrenade
Car: 1989 Nissan 240sx
I think there is some info in the sticky about what your car can handle. I have 189,000 miles and plan to boost soon. With a safe tune of timing and fuel anything is possible to a certain extent.
Jookmasta
compression test will tell you and us where ur engine stands. also a visual inspection would probably be able to help u out as well as a test drive.
Chezedik
Car: 1991 Nissan 240sx
Jook has done some good stuff, but I think you need to think about a rebuild before you start worrying about kicking your motor in the balls (boost). When you build it right, it will do good things. Also, people like Jook taught me that maybe boost isn't as important as a well rounded setup and a proper understanding of exactly what boost is. Long story short, do some searches.
Jookmasta
do keep in mind that i did boost my ka at 142K and it is a daily driver and it just past 151K i think a month ago..............then again i am the original owner so i guess i would know what needs fixing, what was fixed, how its been driven, when the oil was changed, what color the oil was etc..........lol.
