steed77 »
https://forums.nicoclub.com/steed77-u138200.html
Thu May 27, 2010 7:36 am
I think you are wasting your time going small turbo. Same effort doing small or med sized turbo.
You will need to look into fuel... so a 255l walbro in-tank will be a must. Injectors most likely will need to be done. PF regulator also. .
Exhaust and intake piping will need to be custom, not imposable by any means, just lots of good pre-planning here. Along with a solid WG and DV valves.
Inter-cooler will be needed. Pipe routing and mounting will also take some effort.
The largest hurdle will be Tuning. You will need a MAP(to log boost) and a WideBand 02(also for logging) at a minimum for tuning. I would also not trust just any tuner.... also you should monitor all this on your own. Boost leaks, fuel changes, and temp all play a huge roll in this. The Apexi Neo is quite limited for adjustments and tables. If they made an AEM EMS system for this car that would be my choice.
Mini Battery and Turbo timer are not needed IMO.
I would not waste $$ and time on the Versa chassis.... I would look for a turbo car to start with, and one that can be tuned much easier.
