s13point5 wrote:
you dont have to use that exact size. find any stud and match the nuts up to that stud size
The manifold is tapped for m10 1.25. Anything longer than 42mm will hit on the turbine housing or the 5 bolt flange. So unless I redrill/tap the manifold, m10 1.25 42mm studs it is...
boostsfed wrote:Go to Ace Hardware, there are some in your area. They have harden carbon studs/bolts in metric sizes
Thanks for that tip, I'll try there tomorrow. I'll be surprised if they actually have what I need, I went to nine stores today, closest I found was 30mm; nobody else even had m10 1.25s...
