:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Oct 06, 2004 4:16 pm
Technically, it's the exhaust gas expanding that drives the turbine wheel, but...
But higher static compresson ratio helps, as does a little more timing advance, etc...there are a TON of factors.
But the main thing that determines spool is the turbine wheel size and the turbine housing A/R.
What are the specs on yours?
- Brian
