89'ClubK's »
https://forums.nicoclub.com/89-clubk-s-u38539.html
Sun Jul 02, 2006 6:55 am
It should spool that quickly, but my friend has the factory unit (A/R.80) and it won't spool until 4500 rpm. No one can figure it out... turbo doesn't leak, and once it finally boost, it moves! Why does it act like a T3?I would clean the MAF, unless your're going w/ the Z32. If you're running the B.O.V atmospherically, you'll need to use a Apexi SAFC- II. Otherwise the car will have incorrect air/fuel ratios, and die at every stop light.Good Luck!
