TrunkMonkey »
https://forums.nicoclub.com/trunkmonkey-u454.html
Tue Aug 05, 2003 12:32 pm
what i meant was, are you looking for low, mid range, or top end performance? a smaller exhaust a/r will give you excellent low and mid range power, but will choke off performance in the higher rpms. vice versa for a larger turbine. it will have more lag, but will produce more peak power.
imo, there is way to much emphasis placed on how fast a turbo will spool up. no one launches or races at 2000-3000 rpms, so why be concerned with boosting so low? the key is to find the least restrictive turbine for the power and boost you want to run.
-demetrius
