Postby
encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.htmlSun Apr 06, 2003 8:18 am
I like NGK V-power plugs, currently I use NGKBKR5E-11, I really like them, this is for N/A though.
When I go turbo I will most likely be running NGKBKR 6 or 7 ES depending on my whp. Go a heat range colder than stock for every 75-100 or so extra hp, this means at least one step colder for your turbo kit, maybe another when you start making serious power.
Postby
oi138 »
https://forums.nicoclub.com/oi138-u2935.htmlSun Apr 06, 2003 8:18 am
i run bkr7e's. Make sure you close the gap on them to around 35/1000ths or so. I drove around for a long time pissed off until i figured that one out. lol
Postby
encasemyheart »
oi138 wrote:i run bkr7e's. Make sure you close the gap on them to around 35/1000ths or so. I drove around for a long time pissed off until i figured that one out. lol
Really? That small? What gap were they at before when it wasn't working so well?
Postby
Jeff240sx »
https://forums.nicoclub.com/jeff240sx-u610.htmlSun Apr 06, 2003 8:18 am
What boost do you run? What ignition system do you have?These make a difference in the gap needed. -Jeff
Postby
oi138 »
stock ignition.I was running stock gap at .044 and at 5 psi it would just blow the spark out. .035 is what i initially went to when it was happening so i stuck with that. I might could go a little higher but i haven't tried it yet.
Postby
Jeff240sx »
oi138 wrote:stock ignition.I was running stock gap at .044 and at 5 psi it would just blow the spark out. .035 is what i initially went to when it was happening so i stuck with that. I might could go a little higher but i haven't tried it yet.
You're heat range is too cold for your motor, and you'll be fouling plugs.I'm running stock ignition with 7 heat range plugs, but at 350+hp (I'll get on a dyno soon enough), and my gap is .027"From what a lot of people have told me is to increase the heat range by 1 step colder for every 100hp you add.-Jeff
Postby
oi138 »
Yeah i know.i've got msd 50lb injectors sitting in my room to be thrown on in the next week or so. I'm only running 5 psi right now because of the stock fuel system. don't worry i'll be running 15 psi soon enough.
