Turbo SOHCs - need help with s-afc
toki
Hey,
I just wired in my s-afc, did the regular diagnostic deal, hot wire 5 in 5 out, 4 cyl, etc. Everything works except the RPM signal! My idle isn't exactly tits, but it sure as hell isn't bouncing between 1100 and 2300 randomly. What could be going on here?
I have it set on 4 cyl, the with the arrow pointing up and to the right.
Has anyone with the SOHC also had this problem?
Thanks.
(I searched...didn't find anything :confused: )
More info
I used the N3-b diagram as the apex'i US update sais to, and the '90 FSM I downloaded lists pin "3" where apex'i sais to tap as 'ignition check', and the reading should be idle speed. I specify it's a 90 FSM because I know there were some early production 89s with the 9.1:1 and who knows, I might have one, or have had one and the car has a 2nd motor, and the ECU may be slightly different....lots of variables here. Any help is appreciated.
toki
Also,
I have the project silvia turbo timer harness in with the base model greddy TT, and a volt meter is wired up from the previous owner in the ****pit. Thats all the other electrical tampering thats been done with the the car.
toki
wow. looks like i'm the only person on NICO with an s-afc on my SOHC! ....
ftrs13
Car: KATs
I may have one soon, but for now, it just sits in the glovebox
Titan
I have one as well, mounted right under my cd player.
Alas, it's not wired in yet, due to damn finals.
toki
jesus I know there is more than one turbo SOHC running around here with an s-afc no one can go take 2 mins to take off the ecu kick plate and look for me? 2 minutes to help a brotha out?!
veilside180sx
i'm about to get one so would be helpful for me as well
toki
well i found info elsewhere, it IS on the correct pin, but im going to try moving it to the dash harness wire and see if that works.
WAbernethy
I have the SAFC II on my sohc. Mine works fine. I don't know what to tell you except check the wiring for good connections and the other obvious stuff you've probably already checked. The tach signal wire should be on a white wire right?
Edit: yellow wire with a red stripe
:rolleyes
toki
damnit damnit damnit.
I moved it to the dash harness wire, exact same deal.
Time to plug someone elses unit it and make sure I just dont have a bunk *** unit.
