http://www.turbofast.com.au/FlowTO4E.html
I was doing calculations on the TO4E turbo and what trim to use, I did my calculations and plotted out numbers for the KA24 on the 50 trim, 54 trim, 57 trim and 60 trim. I made 2 lines, one for my psi when I get the turbo on (12psi) and one for after the rebuild (18psi)
Here are my results:
Boost 12psi 18psi
60 trim 3800 4550
57 trim 3250 4300
54 trim 3450 3750
50 trim 3200 3400
These numbers are the different trims, above is the psi they were measured at, and the 4 digit number is the theoretical rpm the turbo should be fully spooled up at.
I was under the assumption that the larger trim #, the larger wheel. This seems to be correct except for one thing. At 18 psi it is pretty linear, the larger the trim, the slower it will take to spool. At 12psi the 57 trim spools alot better than the 60 trim, but WORSE than the 54 trim,a nd only very slightly worse than the 50 trim. How can a much larger trim spool up quicker/the same as than the 2 trims below it?
I'm assuming the wheels have different characteristics, they are not just smaller versions of one another, or my calculations are wrong. But I triple checked the calculations. Can someone please explain this?
BTW I realize the turbos will spool differently based on alot of things, but this should be a fairly rough idea of spool time with no exhaust restriction and equal length manifold non ball bearing.
If my findings are correct, it would seem the to4e 57 trim would be the correct choice, good spool at 12psi for street and decent spool at 18psi for race applications. They are all in good efficiency ranges too, mostly 76%.
