Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Sep 11, 2004 9:11 am
you're probably fine. blowby is usually indicative of massive amounts of oil in the intake tubes. I should have snapped some shots of my intake setup when my turbo went out on me. That was a mess and a half.
Anyways, if it slightly moves, but feels stiff otherwise, you're in the clear. These turbos are junkers technically speaking, so they won't be brand new, no play at all stiff. Mine's like that only because i rebuilt it.
Another indicator that your turbo is beginning to die is an inability to hold boost. My turbo used to hold 14 PSI really easy, but then slowly I noticed that it would build up to ~13 and then the boost would fall off and stabalize at ~7. Since the rebuild, it holds steady where I set it.
