hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Tue Apr 26, 2005 3:01 pm
well first off don't just run everything like crazy the second you get it. there is debate on how much breaking in is required for things, but i'd drive at least 500 miles without boosting up much, and definitely not taking it to redline.
once things are broken in well then you need to worry about whether or not the timing is going to screw you. people have bad experiences with leaving the timing alone and running on stock ecu with an fmu. i have seen more than one occasion of someone blowing up their engine because the did not retard the timing. so regardless of whether or not it is possible just do it because you don't want to toast your new engine. once you have an upgraded fuel management (better electronics or madified stock board) with different timing maps then it's not a concern, but for now just be careful and retard it the reccommended amount (1/2 degree per psi over atmospheric pressure i believe)... so if you're running 7 psi then retard ~3.5-4 degrees.
