quest »
https://forums.nicoclub.com/quest-u7580.html
Tue Jan 13, 2004 4:19 am
DSM guys complain about the 60-1 wheel spool dropoff between shifts also. Its a heavy wheel, so turbine housing won't solve it, only choke off the top end. The starion 2.6 slaps it around pretty good tho. DSM guys have swapped between the 60-1 and 50trim(turbonetics), same stg3/0.63 on same cars. The 50 is much better all accross the board.
jgstools.com posted about a small t3/4 that may be perfect for the ca. Made 375whp on a mazda 1.8 @~18psi. t04b with GN or s-trim/ stg1/ 0.48. Not bad for a brand new $600 responsive turbo. hit him up
A guy on freshalloy has a fast SR, bolt-on turbo upgraded off his core.Ran to4b comp (with v-trim? wheel I think he emailed me). Machined stock sr 0.64 hsg for a bigger turbine wheel. At 22psi it left long black tire marks in 4th gear, dry road. Thats torque! Had the 360 thrust bearing mod. Did 367whp on safc, 550s
Doesn't atpturbo, cheapturbo or somebody sells those gt25 and 28s for $775 ?
FP big28 put down 335whp/345tq on freshalloy. ~18psi. $750. stock SR n jwt 740cc programme. Not bad. One dsm made 348whp/376tq on same turbo. stock 2nd gen 4g63 with standalone. Ran the new FP $125 wastegate to maintain boost at hi rpms. I'd rig an hks $55 adj instead.
I'm gonna run mitsu turbos on both my CAs - proven, rugged at 20+psi, responsive, inexpensive, etc... Evo 16G is $550 shipped for a brand new complete turbo. One 2gen 3300+ lb car has gone 12.2 with it! He and others had boost creeep probs tho (gotta look into that). At one time he hit over 28psi at over ~5500rpm, so u know the turbo definitely flows. Not bad for a lo cost responsive turbo. I'll make a manifold for all the obvious reasons.
