f150intally wrote:WTF? that is what i told him. a t3/t04e turbo is a t04 compressor with an e cover mated to a t3 turbine. this combination will not make 500 whp. the limit is about 400whp on this setup, that includes a stage 5 wheel. the stage 3 wheel will not get you to 400whp. Expect to see 21 psi by about 4600-4800rpm with a 2.0 liter 4 cylinder. it may be quicker on a 6 cylinder.
I know what you are saying, and I know what a t3/to4e is... the area I disagreed with you on is the stage 3 wheel versus the stage 5 wheel.
Ok lets do it this way... Even if you don't intend to buy from PTE (where alot of people get the "sc61" or "sc50" etc... VERY good company), call up PTE and ask their opinion. FIRST HAND, a 50 trim t4 in an e cover with a stage 3 t3 turbine wheel in a .63 a/r t3 turbine housing will make EASILY over 400 whp (this turbo is VERY underrated, and I'm sure PTE will tell you this)... on a 2L:
http://www.twingles.com/ideck/ <- 503whp on pump here
Also 4600-4800 full boost is crazy, most 2L 4s see 20psi around 4000.
