Turbo Seal ??
Chase300
Car: 1990 300zx TT
Is it possible to visually inspect a turbo off of the engine to see if turbo seal is hooped?
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Look at the turbo for oily residue. You will usually find it on the compressor side of the housing. Look at the fins and the inlet/outlet. If you find oil, most likely a seal is going. Also check the axial play (in and out, not up and down). If you are getting axial play, your turbo needs rebuilt/replaced.
