evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Feb 15, 2009 10:40 am
the stock ecu will nto work wil those injectors, at least not well, it'll be pig rich, and most likely fuel fowl the spark plugs, stock ecu is meant to be sue with stock flow injectors, when you put in larger injectors the ecu keeps the same duty cycle which results in lots of extra fuel
I did't say your car was a 2+2, I was trying to point out that the 2+2 uses the same flywheel and clutch as the turbo, so if you can't find a turbo flywheel, the 2+2 flywheel is the same thing
if your trans is a 4 speed there are only 2 versions, the 70-71.5 and the 71.5-78 versions, the realy one is kinda rare so I'd bet you have the later style, any datsun L6 trans will work with any Datsun L6 clutch and flywheel
