Use a ECU upgrade for 444cc injectors, 450 is close enough.Personally I never swap injectors on a T25 set up but up to you, most 444cc programs are made for T28 turbo´s and bigger MAF (AFM) but you might find one for the T25.Logan76 wrote:Alright to start the fun off. I just got done talking to my buddy and hes giving me a good SR T25, no shaft play, good condition he took it off as soon as he got his motorset to put on a T28, and a VLSD for my GT-Spec exhaust, and today he gave me DSM 450's, im buying a turboXS MBC, and I know I need some kind of FPR and management, What boost can I safely run 15lbs, with the 450's? My freind has a subbie and is using a tactrix cable and a program he downloaded that plug's right into the OBDII port on his WRX, Is there something like that out there for me? I dont know much about tuning so any info and help you could give me would be helpful, Thanks.
Can you explain why he wouldnt want to get a GT28RS?c-rad wrote:Don't get a GT28RS
Yes I can... the GT2871R is the same price and is even available with the Nissan style compressor housing but capable of 400hp and has the same spool up characteristics as the 28RS.davidricardo86 wrote:
So for the money youre going to be spending on the 28RS, you might as well have spent it on the gt2871r because of these advantages. These turbos arent rebuildable right? Whats the ballpark prices for both of these puppies?c-rad wrote:
Yep, stock lines will work fine.Logan76 wrote:Hey C-rad, do you know if I can still use my stock oil feed and return lines on my SR T25 that I used on the CA one?
Sounds fairLogan76 wrote:well then I will blow 1lb of hot air until I get a bigger turbo near summer Ryon
