Turbo's in, now I got some CEL codes
GTS
I'll start with my setup
TD06 20GCast Iron Manifold2.25" DP2.25" high flow3" HKS Hi PowerAEM WideBandAEM Tru BoostMegan FMICGreddy Emanage
The car is running fine, but I'm getting CEL P0443 (EVAP) and P0325 (Knock Sensor).
I've check most of the sensors and they all look clean. From what I can tell 0443 is something to do with the EVAP canistor selonoid, so I'm hoping I don't have to replace the whole thing.
The knock sensor, I just changed it about a month, so I think it's still health.
Does anyone have any suggestions?
WDRacing
Well, when you plugged your EGR system you made it throw the codes...the knock sensor is under the intake manifold, has one wire and one bolt.
WD
