Project240 »
https://forums.nicoclub.com/project240-u5974.html
Fri Dec 28, 2007 9:44 am
First of all, this might be a dumb question because the answer might be obvious; I'm just hoping that the obvious answer isn't the correct one. The wheels on the turbo I'm about to install spin freely, and it has what seems to be a minimal amount of shaft play, both side-to-side and in-out.
However, if I put some sideways pressure on the wheel, and spin it, I can hear the turbine wheel grazing the side of the housing. This is only if I put pressure on the wheel when I turn it; without any pressure it spins perfectly fine.
Bad turbo, or no?
