Just to add to what virus was saying so you don't think that is on stock injectors. stock injectors on 280whp will blow up your engine .virus77 wrote:I would say a safe mount is ~280whp and the motor should last as long as it would have non turbo.
If not an fmu then what?virus77 wrote:Theres a pretty blinking red button on the top right side of your screen, get aquainted with it. Im bored at work so ill answer a few of your questions.
-you dont need aftermarket injectors with an FMU, but I suggest looking into some other form of fuel management since an FMU is pretty inferior.
-"A good psi to run" that shows you need to study up but I would say you should start around 6-8 psi on any turbo you happen to get for beginners. just to get used to things. The motor will handle a good amount of power if it has a proper running turbo kit (this means good engine management, not an FMU for one). I would say a safe mount is ~280whp and the motor should last as long as it would have non turbo.
