turbo question
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
i'm kinda cheap and i don't wanna spend 2000 on a turbo kit so i was wonderin whats the cheapiest turbo kit for the 89 240sx,also if there isn't any cheap ones i was wondering whats the maximum psi i can run without an intercooler,while not frying my turbo.
Hijacker
Car: '92 240sx Convertible
'94 F-150
intercoolers don't protect the turbo. they protect the engine.
i know some lancer guys that run with 5 PSI or so and get away without an IC, but I personally don't reccommend it
Oatmealman
thanks,but do you know of any cheap turbo kits
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
cheap can be a bad thing, 2k for a turbo kit is a good deal.
nab911
Car: 93 Nissan 240SX SE
The cheapest is a peiced together kit, but you have to have good knowledge of the field to do it right.
Oatmealman
i'm thinking of doing it myself with and intercooler pulled out of another car and a turbo out of a stealth rttt,so i can basically piece it together really cheaply.
Hijacker
'94 F-150
You can find a lot of good OE intercoolers. Volvo makes some good ones. But if you go that route, you better know how to weld. Custom ICs need custom pipes.
Oatmealman
my dad knows how to weld ,but i was gonna buy pvc piping for the ic,since it's cheap,and you can buy elbows,reducers,etc,etc,etc
Oatmealman
also do i need to build the engine cause i was only gonna run like 7psi,if i do what do i have to build
Hijacker
'94 F-150
if you run 7 psi, you should be fine. that's the upper limit i would run a stock KA.
i dunno about the PCV idea. i'm trying to figure in my head if that will disrupt air flow or not
Oatmealman
yeah i cheap so i basiccally want a cheap *** turbo'd car that will run decent if take it to the track,cause i'm in denver so a car may run 16's there,but here it runs like 18's-19's
Oatmealman
bumpity-bump-o
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
if you're smart about it you can pull it off...if not, you're gonna build a big POS
read up alot on turbo KA forums and read up on home made turbo setups
Oatmealman
thanks,oh and tell your girl i said hi
Syntax360
Car: 1986 Nissan 300ZX Turbo
Why don't you just hop in ur RB26 S14 or ur 3000GT that runs 9's or whatever other lies u used to trash up this board with.
With enough fuel you'll be fine. Guys run 17psi on race gas w/o intercoolers on my Z all the time. You COULD get away with it as long as u had the fuel to back it up, but I wouldn't advise it. I think most KA boys stick w/ the garrett T3 outta the 80's model 300ZX's. That should be about ~300 from a junkyard. Another $200 would be well spent on a late model MKIV supra intercooler. About as efficient as you're going to get out of a junkyard. As for fuel, if you again want to cheap out, check out the EIC (extra injector controller) combo that SDS offers - it can float another 150hp worth of fuel, which is about all you're going to be able to pull outta a 2k turbo setup.
NoStickers
Car: 1991 240sx w/ sr (RIP)
1989 240sx w/ ka
1996 240sx donor car (coming soon)
pvc doesnt take heat too well
SeVa-S13
Car: '05 GTO 6spd
Large diameter and reinforced (think large diesel trucks) radiator hoses work fine for both sides of the IC piping at that pressure.
Oatmealman
aight thanks guysbut would the pvc stand up tot he heat
Oatmealman
[QUOTE]Originally posted by Syntax360 "]Why don't you just hop in ur RB26 S14 or ur 3000GT that runs 9's or whatever other lies u used to trash up this board with
sorry but my cars not an s14 and my bro has that 3000gt
NoStickers
1989 240sx w/ ka
Well I have a temporary pvc intake and it has lasted 6 months but its just a really small piece. I wouldn't feel safe with all my intercooler piping being pvc. I've felt my intake which is sch 40 after driving for about 30 minutes and it seemed to be really weak.
SeVa-S13
Car: '05 GTO 6spd
PVC is NOT to be used on the hot side of an IC.
StrangeLove
Car: 1995 Nissan 240sx
Turbo kit is easy!
Find a used turbo from a z31
just grab a log style manifold
a stock CA or SR smic
make your own intercooler pipes with aluminum pipes, silicon couplers, and clamps
find a used bov
cheap boost controller
you can find premade kits for the oil lines
no welding needed!
The key is cheap and used! and installed yourself
A setup like above will get you to 4 or 5psi, but do not go over that, the stock injectors are only good for 6psi at the most
at 5psi you should be close or at 200hp, right?
This was my plan, and I was going to be turbo'ed for just $900
enjoy
