Shouldn't be a problem, you just wont really make boost well... Your car might also run like **** because of that.... So would personally wait, not much point.BlAcK95sE wrote:i blew my stock turbo for the second time... so i upgraded to a hks 2510, and i haven't been able to find a waste gate actuator for it... my question is would it hurt my car or my turbo to drive the car with out the actuator?
Without the actuator, the gate will stay closed right? In which case it won't vent any of the exhaust gas after you hit what should be your safe boost limit, and you'll just keep building more and more boost...Shocker wrote:
no the valve that vents the wastegate gasses is just on a hinge the actuator is what actually keeps it from opening on its own. So it will just always be venting...Eikon wrote:W/out a wastegate actuator, you basically have no wastegate. This means you have no way of getting rid of the excess pressure at the turbo.
If you drive like Grandma and never get into boost, you'll be ok. But if you get on it just once, you'll spike boost and wreck something.
yeah you should be ok. Be nice to her though and find an actuator asap!BlAcK95sE wrote:well i just need to drive my car untill i can find one/ afford one. hks discontinued the acuator for the 25XX series turbos. now the only place i can get one form is Japan. my wife and i only have 1 car now and it kinda sucks.
so would it be ok to drive the car if i don't take it above 3000 RPM
bingo.Shocker wrote:Shouldn't be a problem, you just wont really make boost well...
the adjustability is a good things14 2510’s wrote:http://cgi.ebay.com/ebaymotors...ZWDVWWhy not get one here. There not that hard to find.or this onehttp://cgi.ebay.com/ebaymotors...ZWDVWI have a 2540 on my rb20 and 2510's on my rb26 these should work.
hey thanks for the link! the cheapest i could find them for was 190 shipped! should i just order one for the t28 or the t25.s14 2510’s wrote:http://cgi.ebay.com/ebaymotors...ZWDVWWhy not get one here. There not that hard to find.or this onehttp://cgi.ebay.com/ebaymotors...ZWDVWI have a 2540 on my rb20 and 2510's on my rb26 these should work.
Modified by s14 2510's at 11:09 AM 12/28/2007
