nb07bcar »
https://forums.nicoclub.com/nb07bcar-u30408.html
Wed Feb 15, 2006 8:51 am
I have a th04-15G turbo and I can't get the car over 5000rpm in 4th gear and 4500 rpm in 5th gear. No speed limiter. I have a 91 ka with sacf2, 460cc injectors, z32 maf, msd fuel pump, 3/8 aluminum fuel line to a custom fuel rail, front mount intercooler, msd btm retarding .5* psi. It just seems to run out of steam at those rpm. I'm at 10psi and afr is at 12 and it doesn't go anywhere. here is the turbo map of the 15G and a map of the turbo I think I might upgrade to 19T. maybe the turbo can't supply enough air?What do you guy think?
