turbo question on rb20
RussianKid
Car: 1992 240sx hatch
what size t3/t4 turbo can i use to make 330-350 whp @ around 1.2bar?
or...
what did you use for turbo upgrade (300+whp) under $600??
yotik
Car: 240sx Hatch
im gonna do a holset hx35 or 40series. should be getting one in a couple of months.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
RussianKid wrote:what size t3/t4 turbo can i use to make 330-350 whp @ around 1.2bar?
or...
50trim should do the trick with a .63 exhaust housing.
MATTs14
Car: Red 1995 Nissan 240sx
Search people!!!Look at other peoples setups and base it on that. And an hx40 on an rb20 will be zero fun. An hx35 will get you at 400 easy with bigger injectors, a tune, and some cams to get that beast going.
An hx40 is too much for a 20. Look around for Cjmart on here, he's a holset whiz and runs a full hx40 on his 25 and says it spools in the upper 4's, it would be much greater on an rb20. Nuff said
RussianKid
^ i spent at least 8 hours searching.... didnt find any good info, just bits and pieces. trim here, trim there, ar here, price there, hks here, ebay there, dyno here, blown turbo there, bigger injectors here, crank through the block there..... but nothing specific. and no solid numbers of any sort.
RussianKid
ok, so i found this for sale locally.... Turbonetics T3/TO4E 57 Trim .64 A/R Turbo $300what do you guys think?
Carl H
good turbo, will make the power you want with decent spool.
yotik
Car: 240sx Hatch
MATTs14 wrote:Search people!!!Look at other peoples setups and base it on that. And an hx40 on an rb20 will be zero fun. An hx35 will get you at 400 easy with bigger injectors, a tune, and some cams to get that beast going.
point taken. im no turbo expert but i was really feelin the hx35 anyway. better price and it would easily reach my goals. im not looking to max anything out. good info
db_s13
Car: 92 VQ30DET 240sx
hx35+E85= WIN!!!... this is the setup in switching to as soon as a nice hx35 comes my way and theres a guy on the forum with a sr20 thats puttin down 378 at the wheels on 93
yotik
Car: 240sx Hatch
thats plenty of power for me. i plan on stopping at 350 this is good to hear!
Cjmartz2k
Car: Hunting for a '89 GTR now
x2 on HX35 being able to get you there and a lot more.
BTW, my HX40 spools in the high 3000's, not 4000's 1 bar by 3.6-3.7k, 1.5 bar by under 4k. It's to big for a 20 though unless it's a straight strip car.
RussianKid
RussianKid wrote:ok, so i found this for sale locally.... Turbonetics T3/TO4E 57 Trim .64 A/R Turbo $300what do you guys think?
i ended up paying $240 for it. came off a rb20 putting down 380ish at the wheels at 12psi. turbo has 1200miles on it and no shaft play what so ever. now i need me 5 bolt o2 housing and external waste gate
db_s13
those number seem inflated a bit, maybe 380ish at 22psi
RussianKid
still a bigger turbo for 240$
thompsont2
Car: 93 nissan 240sx rb20det
go hx35 it make a ton of power
MATTs14
Cjmartz2k wrote:x2 on HX35 being able to get you there and a lot more.
Lol thats my bad man. Sorry for the false info. I was locked into the reply board and didnt wanna get out to go find the right number you are the holset whiz and who got me into them.
Holset hx35 or even the hy35 will get you to 350 easily, the hy35 is smaller and will get you there quicker, while the hx35 leaves you more room for power later on. Either way is great. Good luck
zanderhorwood
Car: Skyline Gts-4
If you use a hx35 on a stock rb20 do you need to change anything?
Cjmartz2k
zanderhorwood wrote:If you use a hx35 on a stock rb20 do you need to change anything?
yes
dsrturbonz
Car: er34gtt ae86 er32gtst
*edit*please contact a forum mod for info on becoming a site sponsor.
yotik
Car: 240sx Hatch
anyone ever run a k26 on the 20?
20DET
i run a t3t4 t04e hybrid with a/r 0.50 its wicked on my rb20det.its on the standard exhaust manifold with 38mm external welded on it nd 3 inch off the turbo back.3 inch intake and 2.5inch pipes all the way to a truck intercooler and a front facing plenum...get boost around 4000rpm and hits very hard
