TheRocket300zxtt wrote:As you can see in my sig, I own a Z32 twin turbo (stock turbos). About a week ago I noticed something strange happening with the turbo's. They would spool up fine in 1st gear, but when I would shift into 2nd gear and accelerate they would spool up for about a second and then slow back down while I have the pedal floored and the car would stop pulling. Like my back isn't glued to the seat. Then in the remaining gears the turbo's feel like they did after they slowed down in 2nd gear, and the car still doesn't seem to pull. I have no idea what it could be. Any idea's would be greatly appreciated.
The only things I can think of are: turbo's are going bad, Leak in the hoses, boost jets, and the absence of a boost controller. Also do I have to reprogram the ECU again after installing downpipes and high flow cats?
Also I have noticed a "tapping" sound coming from the engine bay. It gets faster when I press the throttle. What could this be?
Thanks,-Chris
Modified by TheRocket300zxtt at 9:07 PM 7/29/2005
1. Your car is probably in safety boost. If you search around on the internet, like on tt.net in tech, there's a write up on it.
2. You don't need to reflash the ecu after doing testpipes and downpipes
3. Tapping is probably the lifters, its a common problem in the Z32's. Running synthetic oil usually helps. Something like royal purple or redline usually takes the sound away then run something like mobil 1
Best of luck.
