the forsaken »
https://forums.nicoclub.com/the-forsaken-u38529.html
Wed Jun 21, 2006 3:13 am
I’ve got a problem with my turbo and I need some good advise from people that know about this topic.
Here is the problem. I have an top mount turbo manifold with an t28 turbo, 28x7.5x2,5 fmic, 480cc injectors, S-afc, 3” full exhaust, walbro 255lph, and turbonettics external waste gate.
Now the t28 has a lot of shaft play, and I really mean a lot. I’ve tested the engine before I bought it and I did not see it smoke or anything, but with that amount of play I’m sure it will start smoking for sure. Now I know the gt28 is the best turbo I can use, but I already have a t3/34 that fits perfectly on my manifold, the trim is a/r. 50 – a/r 63
Anyway my question is how good is the t3/t4 for the ca18detI bought the turbo from a guy how had it on his ca18det, and his manifold broke, and he changed and went back stock. All I know is that it started spooling between 3500and 4000 rpm. But I don’t know at what rpm it will be at 12 to 13 psi. I don’t want to be getting the full power till after 5200rpm. My goal is to boost 17/18 psi, but first I’ll need to have everything in place, but that’s something else.
I’ve been told that such a big turbo will give me problems with some things. Fuel cut, air flow meter, ext.
Now I’d like to know the pros and the cons of this t3/t4 set up and if I should stay with the t28 at stock boost for some months and then buy a gt28, if I can get the money. I’m trying to sell the t3/t4 but I did not have much success with that. So I’m thinking of keeping it, since I have the down pipe and all. But I don’t want to have problems with it, cause it is my daily driver.
Please help me with the right info, so I can do the right thing for now.Thx.
