mkory wrote:So backing it up 2 posts... Whats the big deal about mandrel bends. Why are they so important? How will I know if a turbo will match up with my manifold?
Also, don't you have to supply oil to the turbo to cool/lubricate it? I see that IWannaS15 included an oil supply kit in his list, but where does this pull oil from and dump oil out?
Mandrel bends, unlike a crush bend, will not decrease the inner diameter of the pipe at the points where it's bent. A crush bent pipe will have crimped bends and won't flow as well. A mandrel bent pipe will be completely smooth and will be the same diameter throughout the pipe.
As for whether your turbo will match up with your manifold, you'll want to buy a manifold that matches your turbo, ie. you've got a T3 turbine you'll need a manifold made for that turbo. Most people here run a T3/TO4E or some kind of straight T3 and most manifolds for the KA will be flanged this way.
There's only one manifold I know of that will let you run a T25, T28 or fancy GT series Garrett turbo and that's the infamous SSAutochrome manifold, as seen on Ebay. General consensus is that the T25 or T28 are too small for the KA, but some folks (AceinHole) have had great results with 'em.
There are also tangential and on-center housings to worry about when choosing a turbo. Also, IIRC some older T3's have 5 bolt housings, which could cause some problems.
Most likely the turbo you will use will just need an oil source and a place for that oil to go, like you said. Some will also have water cooling. Your oil source will be where your stock oil pressure sender is, near your oil filter. You can either T-off of that or get a filter sandwich adapter, which SPL sells. IMO, I think the adapter looks better than a mess of T's and other fittings hanging off the engine block. It will also be less likely to crack compared to brass fittings. Some folks run a restrictor between the block and the turbo, but to be quite honest I'm not sure of the necessity of that or the restrictor size you'd need.
Your oil return line will go to your oil pan. You'll need to weld a bung in to the pan and run a line down there. There are some good threads about where exactly to weld the bung in to the pan. You want a nice straight, easy path for the oil to flow down so you drain properly and don't get oil leaking past the seals in your turbo.
That's my 2¢. I'm still working on designing/piecing together a turbo set-up for my car. Lack of money and the necessity of repairing stuff on my poor old S13 has been holding me back, but at least I've had time to research ALOT. I guess that's one benefit of being poor.
