WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue Nov 17, 2009 6:16 am
Once you start making over 420ish whp you're probably going to need race gas or alcohol injection. Most turbo's that support 500whp are going to make right around 400 at 20 psi. Everything will depend on tuning and supporting mods of course, like cams etc.
The larger turbo's aren't THAT much more efficient that they allow for more boost without the added octane.
The T3/TO4E with the .63 AR exhaust housing will support 500whp when matched with atleast a 38mm wastegate. But like I said, you'll need race fuel or alky by then.
If you run a large turbo, like a T67 or TO4E you will make more power with less boost. But you also have less time under the power curve because of the lag. Depending on the turbo selection, we're talking about 2500 of added lag. The T3/T04E .63AR was at full song by 3200ish rpm, I also have a TO4E .81AR that I'm using now, and was using before I popped the motor, it didn't see full boost until 4800-5000 rpm. Granted, it pulls hard when it spools, but the difference in HP production doesn't outweigh the lag in my personal opinion.
As far as your setup goes, as long as the internals are of any name brand and they are forged/balanced/installed by professionals your block itself will hold over 500whp. In fact your head will lift before the internals will let go. So it's all about the supporting mods attached to the motor now. The most important is how you're tuning everything. Almost any turbo bigger then a standard T3 will make more then 400whp on the KA.
I suggest the T3/TO4E .63AR hotside, 50 trim compressor and atleast a 38mm wastegate. That will support right around 400whp and have almost no lag at all. If you need to make 500-600 at the track, just add nitrous. The new systems these days are very safe and almost idiot proof. That way you have a car that pulls like a C5 Vette off the line and can still make a 10 second pass if you need it to. If you want a little more room for power, use the .86AR, touch more lag but it allows a little more flow.
The key to power production at higher boost levels isn't the compressor, it's the exhaust housing being able to move the air out. Which is why the T28 is just to small, it becomes a restriction to flow at 7 psi and actually causes exhaust gas reversion much after that.
Sorry, I get rambling sometimes
What was the question?
