Chezedik wrote:Not likely, if it is screeching, then there is probably contact between the compressor and wheel. If you pop off the compressor housing and there is not any wear on it, then you can just change the bearings. But you may be F'd if there is any contact. It may require a full rebuild. If you like I have a T3 compressor I am selling, but you would want to rebalance the wheel. Of course, not as much power there, but undamaged.
There's definitely compressor contact. I can see the scrape marks on the inside of the compressor inlet. These marks had been polished off, so I didn't see them upon inspection.../sigh.
It can still be rebuilt, though, right? I noticed that the compressor fins (major) have little rolled edges from contact. I really didn't notice that before I installed the turbo and re-plumbed my entire system. Think it'll be ok, still?
Thanks!
