turbo outlet pipe bolts?
HiWayRoll
Car: 1995 Nissan 240sx
hey guys, My stock turbo outlet pipe on my SR keeps backing off, because some of the nuts have fallen off, but even one of my bolts have back out. Does anyone know what size/ of bolts they are? I need to get some A.S.A.P.
rudee023
Car: '03 Infiniti Q45
M6 x 1.25 Not sure how long though. Maybe 70mm?
dustyk
when you say the bolts for the turbo outlet, do you mean the bolts and nuts that hold the outlet pipe onto the turbo? or the 3 bolts that hold the outlet onto the downpipe? If you meant he turbo/outlet pipe flange, those 5 bolts and nuts are M8 x 1.25. You can get self locking nuts (the metal kind, not the ones with nylon inserts as they will melt) and they wont backoff unless you to remove them, as for the bolts, they caused a problem for me so I replaced all the bolts with studs and used self locking nuts on them as well. You can get both the studs and locking nuts from ATP turbo
