Turbo Outlet Gasket P/N?
float_6969
Ok, so I used the P/N up in the faq for the turbo outlet gasket and they say it's not a part number. I kinda have my car dissasembled right now and need the correct gasket ASAP. I already tried one from a Z turbo and it's only a 4 bolt flange instead of a 5 bolt. What about a 200sx turbo? Do you think if I put it back together with the old one it will seal? I don't really want to trade one exaust leak for another.
Jezz_s13
Car: Sil80 Track Car
11-01 14445-26E00 GASKET - TURBOCHARGER OUTLET NONE NONE R 203.47
Look here...http://www.nissan.co.za/buying_parts_passen.asp
NeedCAforS13
Car: CA swapped S13 coupe
no US equivilent that I know of Ryan... Paul couldn't find one way back when either:(
Keep using the piece you have and maybe coat it in some of that high temp gasket prep stuff. The copper stuff I used on my headgasket works well for turbo/exhaust gaskets:)
Sean
boost_boy
The surfaces should be true enough to the point of not needing one.
Dee
float_6969
I ended up using some hi temp silicon gasket sealer (700*F). It smoked for a little while when I first started it up, but it quit. Seems to have sealed perfectly. Oh well, I'm spooling again, so I'm happy. I forgot how much I missed boost! Thanks guys.
