thats true these forums are helpfuln i never been a forum guynametakennow wrote:That's what a wastegate actuator is for, guys.
well i was planning to put those mods on pretty soonn yea for a stock automatic its pretty quicki ran 17s on the track n that was with a really late startlivinloud98 wrote:doing an exhaust and intake wouldnt be enough power to have to mod the cvt right?
stock my car eats civics, fits corollas, and celicasi cant beat at tc starting at 0mph but if we do a 20mph roll ive beaten the tC..
i found that when you start in low you get a better take off..and than hit it up into drive with over drive off and than put over drive on once you get up to like 50 mphdavid_mejia9190 wrote:well i was planning to put those mods on pretty soonn yea for a stock automatic its pretty quicki ran 17s on the track n that was with a really late start
it does have a torque converter. Just a locking converter that locks earlier than in most cars. You can feel when it locks and unlocks cause the car slows down a lot when you let go of the gas but when it gets to around 40 kph (whatever that is in mph) it starts to coast better.nametakennow wrote:It doesn't slip as much because there's no torque converter nonsense to slip.
I personally think a DSG/SST/dual clutch is a better transmission, but in the long run they may end up coexisting.
yeah i already have an extra bat in the back but from what i read the car only has a 110 amp alternator, as soon as i see one being made for this car that is higher amperage i will buy it.. and i wansnt comparing the DSG to the cvt i was comparing conventional auto to cvt... but is the dsg what the GT-R uses?nametakennow wrote:A DSG is not a conventional auto, it's an automated manual with dual clutches. My reasoning for preferring it has to do with longevity and performance. It "shifts smooth" because it doesn't shift, and while it performs well enough that it might replace the conventional automatic in most applications, performance vehicles will need the sort of response that a CVT just can't deliver. I also can't see the CVT belts taking punishment for as long as conventional parts do.
You should definitely look into a higher output electrical system. Since the engine is fairly new this may be difficult, but if it's causing issues with control inputs, especially given that the car also has electric power steering, that's scary stuff.
if not theres always the warranty on itlivinloud98 wrote:well ill tell ya how my CVT holds up beacuse i bought my car in september and i already have 15k miles on it since i commute to school, so withing 2 years my car is gonna have a good amount of milage on it...
hope these things are durable lol
pretty sure the waranty is only 36,000 milesdavid_mejia9190 wrote:if not theres always the warranty on it
This is an altima cvt turbo, http://www.youtube.com/watch?v=1Q_yWMziHYslivinloud98 wrote:the CVT may need to be modified to be more pressurized...that way when the driveshaft spins inside the transmission case it will be grabbed faster than it normally would... idk i didnt even think about that till now
and how would a turbo work with that, beacuse it blows off when the car shift to a higher gear? the sentra when you floor it it just sits at 6krpms and doesnt move as you keep accelerating? and pressure in the turbo would just keep building... that could be good in one way but bad at another that youd have to let off the gas for the prssure to relase
am i right?
