Turbo oil supply question..
Quicsilvia
Car: s14
Im throwing together some parts to boost my ka and i was thinking i could use a Sandwich plate for oil feed and return lines to save me work insted of welding a fitting on the oil pan..do you think this is a good idea?
NateDogg
The oil requires a vertical drain or the turbo will overfill with oil and burn blue.
You need a gravity drain into the top of the oil pan. Nice try though!
Florida240sx
Got to weld the pan if you want to be safe... I did one of the weldless kits (IAP) didn't trust it... Drop the pan... it'll be fun
Quicsilvia
Car: s14
alrighty..thanks guys
480sx
Car: 1996 Pearl White 240sx
Dropping the pan's so freaken easy, you just cant listen to the damn FSM.
Take off all the bolts on the oil pan. Then get your car as low as you possibly can while still being able to get underneath it with a creeper. Take the wheels off and put it on jack stands if you have to. Take the motor mount nuts off. Jack up on the AC, or AC bracket until the motor comes up about 3-5 inches on the driver side. You might need to take off your valve cover to do this, im not really sure my heads were off when i did mine. At this point the only thing holding your oil pan up is the liquid gasket. Take a rubber hammer and beat a few times at a downward angle and bam its off. Do NOT take a screw driver and pry between the block and the oil pan, you will mess up the mating surfaces and possibly cause an oil leak. Next take a 12 mm socket and take off the two bolts that hold the oil pickup on. There is a gasket there, make sure you keep tabs on it cuz you need it when you finish.
Bam, done. Less than 30 min, no headaches.
When putting it back on i would recommend using Permatex Ultra Grey, you can get it at napa or wherever its good stuff. I torqed all the bolts down to 10 when i put it back on. Might be a little to much, im not sure, but you dont want to tighten them anymore than that. The liquid gasket needs a little room to form a good seal.
Hope this helps you out, it beats the crap out of taking off the front crossmember.
