Turbo oil lines
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
I'm havinf trouble gettin a line to screw into my t28, is it safe to use a rubber fuel line hose to oil the turbo? or will it blow out under pressure?
Shri
Secret squirrel
Car: 1990 240sx w/ ca18det
id think its a little hot down there for rubber fuel line dont u think?
SS
tyrannix
Car: go big or go home
what kind of trouble?
if its that you cant get it in tehre because the flange to teh manifold is blocking it, youll need to rotate the center. its 4 bolts on teh turbine side, and 6 on the compressor side. loosen them up, rotate the center a little so you can get to it, then make sure you tighten them correctly (and make sure you can still get to where the coolant lines go to.... and make sure your oil drain isnt hitting your steering column, i just had to pull mine off and cut it back a bit and use a longer hose to get it to fit)
CJ
XTCshri2222
tyrannix wrote:what kind of trouble?
CJ
I was tring to use steal line, but I can't find any size that will screw into the T28, the original like to the T25 is to small.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
i have 36" SS teflon lined oil feed lines, that will work, but you have to get a -4 to 7/16th inverted flare fitting for the turbo.
float_6969
You can also check out some of our other advertisers, as they are the ones supporting this site and making it free to use.
