turbo/oil lines help. i turned my car on and there was an oil bath
maku_gx
Car: 240sx
hey
straight to the point so I'm wondering whats that im missing on the oil/turbo lines. apparently some kind of washer.but im not sure which. anyone knows?
details
I turned on the car and there was oil all over the floor soon after.it was also on top of the oil pan, so my guess is that i DID put the oil/turbo lines improperly.
so now I'm wondering whats that I gotta do to put em back togather, and if theres a need to pull the exhaust out again. hope not cuz it took me 2 weeks to put it back togather (newbie)
thanks
PS: got any pics of the part i need to get?and idea which store?
driftset
Car: notch top powered s14
if your talking about the banjo fitings,it sounds like your missing the copper washers that were probally on there b4 you took everything off...find them. and no you dont need to take the whole mani off to get to the ones that go to the block,if there missing on the turbo connection u r in for a long weekend.
maku_gx
Car: 240sx
driftset wrote:if your talking about the banjo fitings,it sounds like your missing the copper washers that were probally on there b4 you took everything off...find them. and no you dont need to take the whole mani off to get to the ones that go to the block,if there missing on the turbo connection u r in for a long weekend.
hey thanks for giving a hand.yeah im not precisely sure, but i know its the "washers" if thats what they r, that go on the end of the line, either next to block or turbo i havnt checked yet.but i will today.i just wanted to know if someone has the messure of whatever piece that is and if its actually a normal washer.
goalguy02
Car: '92 240
Its a special washer that is used. Also called a crush washer.
Kalypso
driftset wrote:if there missing on the turbo connection u r in for a long weekend.
it wont take that long, just make sureyou have a good view,and plenty of light.
I had the same problem but I ordered some new lines, and they should be here in a week.
this thread shows you how to install the lines, near the bottom. zer...age=7
you can ask your dealershipfor crush washers for anissan sentra se-r's turbo lines.
they'll have em for cheap
bruinbear714
goalguy02 wrote:Its a special washer that is used. Also called a crush washer.
Also make sure you don't reuse the old one as it can cause problems later down the road.
And finally, don't overtorque the banjo bolt! That will crack the thread housing on the block and then you'll REALLY have problems.
driftset
idk i used mine 2wice and since they didnt seem to be marked up or crushed to bad there holding up pretty good, just dont gorilla torque them on !
