daniel240 »
https://forums.nicoclub.com/daniel240-u4418.html
Sun Mar 07, 2004 1:01 pm
well i finally got it off, and welded a new return in were XS recommends the hole, 35mm from the top, so i will see if it works tommorrow.
there was a little bit of rubbing marks on the housing when i took it off. before i installed the turbo on my car when it was new, i noticed the wheel was very, very close to the housing so i figured thats what the marks were from. they were smooth marks, and i just sanded on it a little with some fine sandpaper. i put it back together and spun it and it doesnt feel like it hits or anything. and like i said before, when everything is together and i wiggle the shaft, there is no play, but when the compressor housing was off, and i wiggled it, there was a lot of play. is it supposed to be like that. i just hope its still good, because its only got 200 miles on it.
