Two-Fortee »
https://forums.nicoclub.com/two-fortee-u80523.html
Sun May 11, 2008 1:15 pm
so, I'm putting my stock turbo back on after some issues with my T28, and I'm having some troubles with my oil line. First of all, its in the turbo, and the manifold is on tight, and I'm trying to get it into the block. It fits into the fitting, but it won't screw in properly at all. Its almost like the bolt is too small for the fitting on the block. I have done the line before probably 2-3 times but this time its different. I'm wondering if you guys have any suggestions. The bolt that goes into the block goes up and down and isn't tight on the line. Is that normal? When its inside the fitting on the block it spins freely and won't catch the threads.
If you guys have no idea, then do you guys know where to get a stainless braided oil feed line for the ca18det? Thanks...
