zachosz »
https://forums.nicoclub.com/zachosz-u2609.html
Fri Jun 20, 2003 10:04 pm
Do some research, learn to read a compressor map, and remember that turbocharging is more than just a turbo and manifold. Any turbo will work for your car, depending of what your goals are. How much power do you want? How much $$$ do you want to spend? These two are almost always directly related. Another thing to consider, factory turbos are usually under-sized, sacrificing power for driveability. For example, a Dodge Daytona makes ~220 hp, which is as high as you would want to go, maybe 250 hp at the most, that's flywheel hp by the way.
A used turbo would need to be rebuilt, so that could add to your cost, maybe you could spend a bit more cash and get a turbo more suitable for the KA.
