fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Tue Feb 28, 2006 8:49 pm
Sometimes it'll take a little while for the oil to get up through the tube. A few back to back periods of cranking should do it, although maybe not if the engine isnt really spinning that fast. Also check for kinks in the line. One time I kinked the oil feed line completely with the intake manifold...
The engine has to be turning to build up oil pressure-- the pump is driven directly by the crank, so just having the key "ON" isnt going to do anything for oil.
If you removed your EGR, it HAS to be blocked off, no question.
Let us know how it goes!
