OriginalWheelman »
https://forums.nicoclub.com/originalwheelman-u40105.html
Thu Apr 27, 2006 7:30 pm
Ok. First off let me say I have been working on cars my whole life. Sadly however, it was on muscle cars. *Hangs head in shame* But I converted after buying my first 240. But I digress..... I'm going to turbo my single cam cause my friend upped the turbo on his RB20 and gave me his turbo, IC, BOV, and piping! What I need to know is how do I tell what flange is on the turbo? It came off a R32 GTS-T. I need to buy a manifold and don't want to buy the wrong one. Is there a way to measure to find out for sure? I know a lot about cars, but nothing about turbos. From what I read 7psi is a good start point, but I also heard it depends on the turbo flange? Any pointers or pitfalls i should avoid? My car has 76k on it, and the motor is tight and strong, no smoke. I'm confident it will handle the turbo well. Also can anyone recomend a turbo timer and boost controller? I have an Apexi SAFC II now, and I was looking at an HKS EVC 5, but others seem cheaper. I don't mind spending the money on a good timer, so long as it's justified. I just can't shell out the 2k for a stand alone. Is there anything else I should get when I turbo? My current set up is an injen intake on a stock single cam, 'custom" exhaust that the guy before me put on, the SAFC II, NGK platinums, and I changed to a rb20 FPR and injectors. I also have a five lug swap planned and I have a set of R32 brakes ready to go on when i do. (Just need some good rims.) I have an R33 diff and a walbro going in it. I'm running the OEM springs on GR-2s.
I appreciate any help you can give me.
Thanks,John
Modified by OriginalWheelman at 10:51 PM 4/27/2006
