zerosalwaysone »
https://forums.nicoclub.com/zerosalwaysone-u214756.html
Thu Jul 18, 2013 7:45 pm
External waste gate, it's not stuck open neither is the blow off valve. The boost gauge doesn't read vacuum only boost, but the blow off valve does release pressure but very little almost like a mouse is coughing on you. The car runs like s*** when the safc2 isn't correcting the a/f it's an ecu tuned by Enjuku for d1 also tried a central 20 tuned ecu didn't run Much different
