ITR_KILLR wrote:A/R, or area ratio, is the way compressor housings and turbine housings are sized.
A/R is not area ratio. If it were area ratio, it would be AR, not A/R. A/R stands for area/radius, as someone mentioned earlier, because it's derived from these measurements on the housing scroll.
BTW, it's a little known fact that larger A/R compressor housings are actually more efficient at LOWER boost levels. So if you want to run high boost, use a smaller A/R compressor housing. Counterintuitive, yes, but it's the truth.
Asad
