civiceater »
https://forums.nicoclub.com/civiceater-u8116.html
Wed Oct 13, 2004 9:21 am
Ok. I'm a noob in terms of Turbo tuning. I'm not in N/A. I want to go turbo on my KA, but I don't know where to start. Can some one post up where I can learn about turbo's, trims, compressor size, types (like them hybrids I see, t3/t4 or t304 or something) and stuff like that? Also like what would I need to start off. My research about the whole thing is very minimal. All I know is this. I need an exhaust manifold, turbo,test pipe,intake pipe/filter,new exhaust piping and for the FMIC, it's basically them pipings and the core itself. Now I just want say around 200-250whp out of it. I don't need the most power I can get. I also don't know anything about engine management besides SAFC which I have no idea to work with either. All I know about it is it can change how lean or rich you run. Also does any one here run a manually controlled engine management? meaning no electronics whatsoever? Cuz I live in cali and I want to have the turbo but when smog comes in I want to get the stock parts in so I pass and go back to turbo aftewards without having to dyno tune anything. Thanks for the help guys.
EDIT: Also I was looking into ECU's from JWT. What is the difference between the FED and CAL? And the turbo ECU's, are they a type of Engine management?
