pjkyle14 »
https://forums.nicoclub.com/pjkyle14-u155712.html
Wed Mar 10, 2010 8:02 am
@seang HOLY BALLS!!!!!! that is some very very nice torque curve going on there!!... lol
well i haven't been on the past couple of days from doing some research, my buddy just totaled his truck, and i am getting the truck for cheap, it is an 01 frontier vg33er with only 39,457mi, since i am getting the entire truck i will be able to do the entire swap... wiring harness, motor, transmission, ecu, etc, i should have about everything i need for swap... "should" you know how that goes it never fails something goes wrong...
also when i was checking out the clearance problem, ur right, i can get the motor to clear the hood but then it will be a problem with the oil pan, or vise versa... the VG33ER from what i see is not much if any wider than the vg30e, other than the SC, but after looking at it, it will sit northeast of the fender well and have plenty of clearance if i can find a good oil pan that fits. now another question to consider, will the vg30e oil pan from a 95 pathfinder fit these vg33er? i can get one one for $5
as for the choice in the swap... i would much rather do the swap to the VG33ER, mostly for kicks and giggles, it would def be a close first(i think), and would make a great conversation piece, rarity etc... and i can buy this super low mile truck for really cheap... if i can just get the POS to fit in right, and no way in hell am i gonna cut a hole in my hood for this swap, that is a lil tacky if you ask me...
@money mikei was mistaken about the torque, i see this now, i was just thinkin of boost lag and not the entire perspective of the motor... thank you for pointing this out, if you follow through with that 500hp motor, do you realize what kind of a beast you would have!?!?!
