Turbo-Manifold Vaccum question
Ca_Silvia
I changed my boost gauge from a crappy Megan one to an Autometer and i noticed a drop in Vaccum from 20 to 16. However at the same time i noticed the turbo loose from the manifold. Would that space in between the Turbo and the Manifold cause the gauge to read low vaccum or is it a boost leak some where else in the system?
Ca_Silvia
Bump-no one knows if an after turbo boost leak will effect a boost gauge reading.
slo
Car: S13
Ca_Silvia wrote:Bump-no one knows if an after turbo boost leak will effect a boost gauge reading.
where did you tap into for your boost reading?
jey_253
Car: 1990 S13 Silvia Conversion Rb25det
being that its on the exhaust side and not intake i dnt think itd measure as a loss in vaccum. but it could i guess cause compressor isnt spinning as fast
Ca_Silvia
Back of the manifold
Ca_Silvia
Ok well alittle hard work and i answered my own question. This past weekend i changed every single vaccum hose nissan but on the bastard as well as properly remounted the turbo to the manifold. And my boost gauge is still reading low (15-16 at idle) However the car has significantly increased in pull and is much smoother as the revs increase. Im still pretty stumped about why the gauge is still reading low but i still need to check the boost gauge line and if that doesn't do it i will make a leak tester but at least the hard **** is done.
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
Maybe because
Ca_Silvia wrote:I changed my boost gauge from a crappy Megan one to an Autometer
float_6969
If it runs fine, I would just think it's a difference in the guages.
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
Mine reads about that (15-16) when at idle... but if i'm in motion and coasting it will vac to about 20-21.
my jetta, also 1.8t, vacs about the same between idle and while in motion in neutral.
Ca_Silvia
[QUOTE=trevr]Mine reads about that (15-16) when at idle... but if i'm in motion and coasting it will vac to about 20-21.[QUOTE]
Thats exactly the same as mine. But i have to agree that it might be the difference in gauges.
progman
plug your megan gauge back in... see what it says.
Modified by progman at 11:38 AM 3/10/2008
