Turbo Manifold Turn Red Hot Glowing
whchua
Car: 96 240
I just got done with my KAT conversion, Stock internal, T25, N60, 370cc, walbro 255, ECU Tuned Emance, timing adjusted PER FSM, 20 deg 700 rpm. I am currently running 7psi. I have a few questions, car started fine at first click, when i run car at 2000rpm for few minutes the turbo manifold turn bright red, getting too hot, is this normal or i am running too lean. As of now i do not have wide banc to confirm my AFR. Can some please advice what should i check or tune next in order to eliminate the red hot manifold. Any advices are appreciated. Thank you!
Doya
Car: '95 240sx KA-T
whchua wrote:I just got done with my KAT conversion, Stock internal, T25, N60, 370cc, walbro 255, ECU Tuned Emance, timing adjusted PER FSM, 20 deg 700 rpm. I am currently running 7psi. I have a few questions, car started fine at first click, when i run car at 2000rpm for few minutes the turbo manifold turn bright red, getting too hot, is this normal or i am running too lean. As of now i do not have wide banc to confirm my AFR. Can some please advice what should i check or tune next in order to eliminate the red hot manifold. Any advices are appreciated. Thank you!
Get a wideband
WDRacing
Is the car under load at 2000rpm or just revved to 2000rpm?
whchua
Car: 96 240
Just revved to 2000rpm no load
WDRacing
If it was lean enough to do that it wouldn't be running at all. It almost sounds like you have fuel being ignited IN the manifold itself.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
hmmm you might have a leaking injector that could cause fuel to ignite in your exhaust manifold. When i had a real bad injector leak and i took off my exhaust manifold and started the car it was SPRAYING fuel out of that exhaust port and actually caught on fire! Got it out right away but still that was scary.
kouki_hmongster
Car: Want 97 kouki
Seriously get a wideband. there could be other things wrong with it but right now at least confirm your car is not too lean or rich. I know you probably anxious to drive it but be a little patient because i dont want to hear about a blown motor.
I think the ka-ters are gettting better since i havent really heard anything about blown motors.
whchua
Car: 96 240
i am getting a wide band right now, get my AFR checked. Thank you very much!!
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Another potential emance victim
+1 on wideband
my car idled at 11:1 with his tune...
