Did you mean turbo manifold? If so, that is a RIDICULOUSLY cheap price for that quality of a manifold. Great job on the fabrication. It's always nice to see quality custom work.Cakesfab wrote: Turbo is now for sale for $800 plus shipping. Serious inquiries only please.
480sx wrote:Really cant believe that your letting this manifold go for so cheap. Your welds are quality, the turbo placement is ideal for a drag setup, and the manifold seems to be built rock solid. Is that thing equal length? Hard to tell.
We are brokeNateDogg wrote:Maybe if it kept the PS you'd have some bites. Looks like a drag only piece...most of Nico is broke DD slobs like me. Try drag240sx or somewhere else.
twin scroll = twin wastegates = faster spooljbracy7 wrote:why twin wastegates
Thanks. I don't like copying other people's stuff.Reno wrote:Cakesfab = Miami240 :0
i remember he raced a 5.0 sprayed 1st gen rx7 good race btw.
was wondering if you can copy other mani's?
like this 1 for example
I think you need to stop looking at the brand so much and just look at the product. There is absolutely nothing special about it. It's just a regular divided manifold with the division removed about half an inch from the edge of the flange. Take a look at the cylinders that are paired and then take a look at mine. If you really want to see the benefits, run a fully divided setup like mine and enjoy.turbonola wrote:have you seen the tomei expreme manifold?
http://www.tomei-p.co.jp/_2003....html
now i know you said you don't copy other manifolds but i don't think they're gonna make one for the ka. i was just wondering if you could make a manifold to mimic the attributes of this manifold. i have 2 friends with sr's and one has this mani one doesn't. needless to say this mani makes a noticable difference.
how many divided t2 flanges do you know of. i'm not worried about brand, i run a cxracing manifold. i just wanna see if that type of manifold can be replicated for ka's. i've seen the difference between a tomei expreme and a regular tubular mani. i was just wondering if you could do it but i'll try it myself next year. i'm going to a tech school to attempt to learn to weld.Cakesfab wrote:
Because you can't install it on a 240SX unless you're getting rid of power steering. Which is retarded unless you're building a race only car. There are manifolds available that don't require 2 wastegates and allow you to keep the power steering AND are roughly the same price.turbonola wrote:i don't see why it won't sell, that thing is pimpin.
Some people are more serious about performance than others. Hopefully there's someone out there that still has a good sized sack.WDRacing wrote:
Yes that manifold looks like a quality unit, but it has some very negative things that come with it.
If you want the full benefit of a divided manifold, you need to keep the exhaust pulses completely separated.... hence two gates instead of one. Each gate port was placed perfectly in the middle of the merge of each pair of cylinders to provide equal flow from each runner. Two gates also provide much better boost control over one. And the fact that i ported the transition from the collector to the turbo flange also means much less turbulence and restriction. Little things like boost control and flow is what causes me to give up some unnecessary accessories. Everything was done with performance in mind and THAT'S what makes it a performance manifold.Razi wrote:I don't think if the manifold FORCES you to remove powersteering doesn't make it a performance manifold.
I'm with WD, I think you can buy manifolds that offer similar performance without forcing you to remove the powersteering and have 2 wastegate.
Kudos on the manifold though, I wish I knew how to weld.
The benefits you gain from this are so outweighed by losing powersteering it's not even worth talking about.Cakesfab wrote:
Modified by Cakesfab at 2:55 PM 12/13/2008
Modified by Cakesfab at 3:33 PM 12/13/2008
