tEknoS13 »
https://forums.nicoclub.com/teknos13-u54586.html
Fri Dec 19, 2008 1:32 pm
Hey guys I need some help here with my exhaust manifold and turbo setup.I puchased te Peak Perfromance exh. manfold a few months backand I ran into this little problem.
The intake pipe gets in the way with one of the tubes from the exhaust manifold and doesn't let the flanges from the turbo and the manifold align like they should.
The above pic has a gap only on that side, the other side sits on right. Im not sure if ones I tighten the studs that gap will close and my problem would be solved, keeping in mind that there should be a gasket in there still.
What do you guys think. I was thinking this would solve my problem but not sure.
