slownslurious »
https://forums.nicoclub.com/slownslurious-u29303.html
Sun Aug 07, 2005 5:19 pm
OK I just finished putting mine in, it took me and my friend the whole weekend. Its nice, response seems a little big worse, I imagine that I feel a slight increase in top end. I'm running everything completely the same as before, stock CA turbo.Some observations:1) this manifold does not mount the turbo in the stock location. Mine mounted it about 1-2" foward (towards the radiator) and 1" or so CLOSER to the engine block. I do not see how this would facilitate a larger (GT28) turbo, since it provided LESS clearance for my stock turbo.2) You will have the bend the **** out of the oil feed line to get it to fit, its a *****.3) water lines have slack, if you loosen the lines on the back of the block you should get them in with no problem.4) oil drain line doesn't fit, at all, irreconcilable difference. I ended up cutting mine up closer to the turbo and running rubber hose all the way down to the oil pan. its not an ideal solution I'll probably replace it later.5) stock IC piping works.6) none of the stock heat shields will fit in place... and this thing gets real hot real quick. I really had to reroute my lines and I'm thinking I may still add some of that heat shield cloth around the brake MC and the vaccuum lines.7) the #2 cyl's top stud actually hits the runner on that cyl on the SS manifold. We ended up cutting about 1/4"-1/2" off the stud for clearance, and then we had to hold the manifold off the stud while we slipped the washer on. It took a long time to get the nut started.8) The manifold hits the valve cover and won't tighten all the way down. Its where a little screw is on the side of the valve cover, so I dented the manifold a tiny bit with a ball peen hammer and it fit. 9) there is no f'n way you could change the turbo on the car, the manifold would have to come off.10) the rear bolts on the manifold are a real *****, to take off the stock one and to put on the SS one.
Overall- this is not a real great manifold, but I only paid $90 for it. Even then I'm a bit disappointed, as it took a LOT of work to get this thing on, and both of our knuckles are raw from all the crap.
If you want to know how you could be better prepared if you are installing yours:Use quality OEM nissan gaskets, the SS ones are crap.Have a die grinder or dremel on hand to grind down the stud where it hits.Don't cry when you have to bang a dent in the manifold. It sucks.Buy an oil drain kit, cause your stock **** sure won't work. An SS oil feed kit would probably make life a bit easier too. Bring small children, their hands might actually be able to turn some of those bolts.
Modified by slownslurious at 11:58 PM 8/8/2005
