Turbo makes no boost. Farewell ceramic blades. Can I still drive it to work?
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
I still need to get to work, will having a turbo that makes no boost damage anything?
Car seems to run fine otherwise. No leaks, idles good. no stumbling under acceration.
Thanks!
Carl H
i wouldnt as the shaft could move and the compressor could gernade next, well assuming the turbine blew up that is.
themadscientist
-1 on the "yes", I clicked the wrong one. If you had a pipe made to bolt between the manifold and the downpipe and pull the munched turbo ok but the busted turbo can still throw debris into your engine if you run it like that. You have probably already sucked up some junk if the exhuast whell shattered so bad the compressor wheel crashed into it's housing. Not worth the risk. A Z31 VG30ET turbo is a good low-buck replacement.
armysweitzer
Car: RB20DET S13
id say drive with the maf unplugged so the turbo really cant make boost or even try really
i still clicked no though, im sure someone can give you a ride? Or do you have insurance that you cant rent a car for cheap?
Vkoslak
Thats what I needed to know. Im pretty sure the exhaust side is what went. The exhaust is much louder and I dont hear any turbo wine at all.
y3llows14
Well, I have had the same thing happen when my turbine ate $hit. It went completely through my exhaust. I can see peices of it in my canister. Billow of smoke came out as well! I wouldnt drive it.
Vkoslak
Fortunately I have a 300zx I can drive. Now I need to know what turbo to get. hehe
I cant decide on getting something that is close to stock so I can get back on the road quickly, or to upgrade fuel injectors and get a powerfc and throw something with a little more umph into the mix. My Z had 280rwhp last time I dynod. I would love to have that from my rb20det. I don't want much turbo lag though.
themadscientist
VG30ET turbo will do that.
Vkoslak
Finding one is another story
Plus I'm not sure I want a used turbo.
Right now I'm leaning towards the hks2530. Should spool nice.
stiergott
Car: 240
as long as there is no crap about to blow into the engine you should be fine. if its an rb25 then its got 9:1 compression and should do ok as a n/a motor for a while, i wouldnt go out and try to drift it or anything.
Nismo_Freak
Car: 89 Nissan 240SX
Hey Rob
There are a few Z31 Turbos at Cap City Imports on South Congress.
Get that thing running again so I can punish it with my SR.
